Results 1 to 8 of 8
Thread: lost down the wormhole
    May 2008
    fremantle
    if a small part feel down the demister vents of a D2 is there a low point where random objects would collect and does anybody know how you would get access to it?
    Oh, now you're in trouble, you know that goes straight into the cooling system.
    Head off at the very least.
    Simon
    May 2008
    fremantle
    Well thank God for that....for a while there I thought I may have been in trouble.
    My only worry is I think it is the spigot lever for the CDL....don't ask.
    No problems now - to engage the cdl just turn on the demister.
    After countless AULRO threads on activating the D2 cdl, you have finally solved it. A cheap and easily implemented solution.
    2024 RRS on the road
    2011 D4 3.0 in the drive way
    1999 D2 V8, in heaven
    1984 RRC, in hell
    Ellendale Tasmania.
    Here a PDF of the heating system, Don't turn the demister on, that way you may be able to get it out from the top.
    Baz.
    Cheers Baz.
    2007 BMW R1200GS
    Australia
    Magnetic pick up tool from supercheap. Its a little magnet on the end of a 60cm flexible stick / shaft/thingy. about 6 dollars and saves many hrs of dismantling, frustration and cursing.
    Jun 2008
    Milton, Queensland
    I think I have a 10cent coin that fell down one of my vents, you can hear it slide around when going around corners and when traversing rough terrein. Will try to use the magnetic tool, but I think it will be very difficult to find.
    cap8959 Guest
    Quote Originally Posted by Hendrik View Post
    I don't think you will have any luck with the magnet on coins, not magnetic. However on the same shelf as the magnet you will find a 3 pronged flexible arm that you position over the item and grasp by pulling a centre cable. God luck finding it.
