It is a pretty inferior piece of kit. As you say it struggles with our climate, and leaks hot air into the passenger accomodation. I blocked off the hot water supply to mine with a Bowden cable operated heater valve in the supply line from the thermostat housing.
) turbo, p/steer, RFSV front axle/trutrack, HF, gullwing windows, double jerrys etc.
