The LR HD springs are good and you will probably find they are also cheaper than a lot of others. When I fitted the ARB bar and winch this dropped the front end and made the handling rather ordinary until I got the new springs in, now its back to what it was before.
If you're putting in long throw shocks, etc. I take it that means you've also removed the sway bars. So was there any change in handling on the road?
Just an aside, the LR HD springs are handed, the standard Puma ones not handed and are identical (part number) to the LH spring of a Tdi/Td5.
