Are you sure the pump is U/S - disconnect the fuel line at the fuel filter to check.  (EDIT wrong information) EDIT - The XEDI does not have a pump in the fuel tank (in fact no lift fuel pump at all - it has a system similar to that of an outboard motor fuel tank - fuel is sucked up and the system pressurised via a rubber hand pressure bulb pump that is located next to the fuel filter.  To bleed the system and to get pressure you crack the valve at the top of the fuel filter and have the ignition on - you then pump the rubber bulb until it becomes hard which means the system is pressurised - you then close the bleed screw on the filter.)  So - has the system been pumped up and bled correctly - then see my note below.
Is the fuel shut-off valve on the fuel injection pump working - if the car has sat for a while it may be seized up in the closed position so the engine will not get fuel.  If it needs a new valve - prices range from $120 to $700 depending on where you get one.
					Reason: First line of informationis wrong - Edit is correct
