                                                25th March 2009, 08:44 PM
			Replacement rocker cover Davies performance TD5
					Anyone know anthing about the replacement rocker cover from Davis Performance apparently vents back to the sump ?
 A bit pricy $180 exchange rocker cover + gasket + if they fit
                                                25th March 2009, 08:56 PM
					Isn't that where the gas pressure came from?
Slunnie
 ~ Discovery II Td5 ~ Discovery 3dr V8 ~ Series IIa 6cyl ute ~  Series II V8 ute  ~ ~ Discovery II Td5 ~ Discovery 3dr V8 ~ Series IIa 6cyl ute ~  Series II V8 ute  ~
                                                25th March 2009, 09:37 PM
					Slunnie,
 I did express it incorredtly it drains the oil back to the sump I'm not sure what it does with the hot air? Whether it takes it to the air intake or straight out?  Hope to see one fitted to a vehicle in the next few weeks but would be interested if anyone has one and or opinions
                                                26th March 2009, 04:06 AM
                                                #4
					Pretty sure they just put extra baffles in the rocker cover to stop the oil.
                                                26th March 2009, 03:28 PM
                                                #5
					Haydofly,
 If that's the case I know where my $180+ will be staying.
 I'll continue on making my own
                                                27th March 2009, 09:19 PM
                                                #6
					I have one, I believe it just has baffles as stated to help condense the oil vapour before it vents to the inlet. Not sure of the difference it has made as it was done when I had a whole bunch of work done when I first got the Td5. You still get oil in the inlet, maybe it's less than with out it but I wouldn't honestly know.
