See here Alternator Service
Connect tacho to the to the 'W' terminal
I've decided to put a rev counter in the 300TDI and can remember seeing a tutorial on how to do it with the rear of the alternator shown, and I cannot find it anywhere . Can anyone help.
Mal
'95 110 300TDI, F&R ARB Lockers, Twine Shower, Aux Sill Tank, Snorkel, Cargo barrier, 9 seats, swingaway wheel carrier, MadMan EMS2
'85 110 Isuzu NA 4BE1 3.6l Diesel, 0.996 LT-95, Rear Maxi (SOLD)
'76 SIII 109" Nissan ED33 5-SP Nissan GBox (SOLD)
Thanks for the info isuzu110, but there was another tutorial with part numbers for the gauges etc. somewhere.???
Mal
For those that want to knowthe VDO part number is 333-156 for 4000rpm rev counter.
Mal
gone
1993 Defender 110 ute "Doris"
1996 Discovery 1
current
Hi Gents,
The correct part no is VDO 33305017G revs to 6000 rpm not the 4000 as previously indicated, there were problems getting one in WA and I cant wait when the money is burning a hole . The loght is yellowy red, i think you you can get a green globe or sleeve to change the colour but I havent as yet. They are quite hard to calibrate as well if you dont have the special rev counter thingy so only an estimate, I do know that the top rev limit is correct as per the 300tdi spec, but the idle seems a bit low? I hope this helps, also dont try and put it in the no1 position next to the speedo as it wont fit because of the dash bracket behind.
Mal
