Thread: Footwell replacement, spot weld drill size?
    Devonport, Tasmania
    Hi all
    I am about to tackle replacing the footwells in "Mongrel" (2A 109 5door) .
    I have tried searching but can't find what size spot weld drill to use. I am sure I read about it in a post some time ago but am unable to find it again.
    Any tips for replacement and drill size would be great. There seems to be a truck load of spot welds in the footwell section!
    Cheers Andy.
    Adelaide Hills. South Australia
    I don't know about size, but there is a special spot weld drill you can purchase. Is this what you mean?
    It fits over the spot & not actually on it so it can be centred. It sounds "tube like" from what I can recall. 1/4" diameter rings a bell.
    I'm sure someone here will know for sure.
    Google for spot weld removal tool/drill.
    a bit rougher than you blokes,
    i'd use a drill straight thru the spot weld, or a chisel!!
    after all it isn't an aeroplane, and it's just a bit of tin to fix it all.
    but i do simplify things when i don't have to follow the rules and it won't kill someone.
    Safe Travels
    harry
    Devonport, Tasmania
    Thanks guys
    Harry, I have drilled straight through most of one side and it looks like there are holes all over the place. There is a lot of bloody welds there! Did you just mig over the holes when you welded it in ?
    I am not going for any you beaut finish on Mongrel, as the vehicle is a mix match of different parts anyway. I intend to make it a basic 5 door Defender substitute, to do a bit of camping and launch the boat.
    I would like a shorty but I can't go past the galvo chassis under Mongrel.
    Any pics or links to your footwell job Harry.
    Cheers Andy.
    Brisbane, Inner East.
    Quote Originally Posted by 4bee View Post
    P&N make them. Ask a stockist for "Cobalt Spot Weld Drills". Available in 8.0mm and 6.5mm diameters in a variety of lengths from 38.0mm to 77.0mm. They have a centre point for location and the cutting edges cut the outside of the weld leaving a round hole on one panel. Not cheap and near impossible to resharpen without a special jig or a tool and cutter grinder.
    URSUSMAJOR
