Results 1 to 10 of 19
Thread: Front drive shaft and uni's, 110 county
    Hey guys... I have been noticing some clunks recently from the front end of my county..
    got under this morning to have a bit of a look and noticed the front uni joint is absolutley shagged....
    Where would be the best place around brissie to get a replacement, (new or secondhand)..
    Or does anyone have a spare there willing to sell to me... Couldn't have come at a worse time as i've got a few trips comming up and very little time inbetween work to try and source one...
    Thanks in advance.
    mikey
    JDNSW's Avatar
    JDNSW is online now RoverLord Silver Subscriber
    Universal joints to fit it will be available from any bearing supply outfit. And they probably will have a reference for the correct one, but to be certain, pull the shaft off and take it (or just the U-joint) with you. There is probably one nearby.
    When replacing the joint, if you have the sliding joint apart, remember to assemble it with the marks aligned, not with the yolks aligned as you would expect.
    SW of Geelong
    Quote Originally Posted by Mikey0211 View Post
    mikey
    For the price of a new one I wouldn't fit a second hand one.
    Murray
    '88 County Isuzu 4Bd1 Turbo Intercooled, '96 Defender 130 CC VNT
    '85 Isuzu 120 Trayback, '72 SIIA SWB Diesel Soft Top
    '56 SI Ute Cab
    Padstow NSW
    i agree ^^^^^
    new ones are quite cheap. despite what you may think
    cheers phil
    Preston Melbourne Vic
    Speaking of uni joints, I noticed mine weren't acccepting grease whe I tried to grease them the other day. Is it worth pulling them apart, cleaning and reassembling them or should I just go and get a new set?
    I have also noticed quite a bit of back lash in the front shaft any ideas how I remedy this?
    If i was to get some replacement uni's where would be the best place in SW sydney?
    SW of Geelong
    Quote Originally Posted by XSiV View Post
    If the movement is in the spline of the prop shaft, you can get the shaft reco'd. There are guys who specialise in this sort of stuff. Basically it involves cutting off the old splines, welding on a new spline section and balancing the shaft. Not cheap though, cost me $400 with new uni's.
    Murray
    '56 SI Ute Cab
    JDNSW's Avatar
    First unscrew the grease nipple and see if the problem is there (likely). Lot easier and cheaper to replace the nipple than the whole U-joint!
    rijidij - my experience is that reconditioning a propshaft on the 110 was going to cost almost double the cost of a new, genuine part, although you might do better if you live in the city and there is a choice of people to do it. Unless my memory is faulty, because of the need to rebalance the shaft and the problems that can arise if it is out of balance, the work has to be done in a workshop specifically approved to do it (in NSW at least).
    Padstow NSW
    Speaking of uni joints, I noticed mine weren't acccepting grease whe I tried to grease them the other day. Is it worth pulling them apart, cleaning and reassembling them or should I just go and get a new set? uni joints from hardie spicer at morebank, heathcoat rd, are around the $30 mark, i couldnt be bothered cleaning one for that
    I have also noticed quite a bit of back lash in the front shaft any ideas how I remedy this? is it in the slip joint or the T/Case?
    answered in the red the front part number should be k5 13xr. not sure if the rear salsbury has larger uni's?
    cheers phil
    Quote Originally Posted by rijidij View Post
    Murray
    Thanks Murray, I just checked out the price of them and a front propshaft from britparts costs $162.87. I think a new one would be the better/cheaper option.
    Quote Originally Posted by discowhite View Post
    cheers phil
    from the transfer case.
