                                                2nd April 2009, 11:04 AM
			 defender wet weather front end noise defender wet weather front end noise
					defender95 makes clunking noise in wet from left front at low speeds,over bumps,on/off braking. Doesn't appear to do it in dry-thou .Live on gravel road.Front bushes?Look ok thou lower radius arm bolt may have some movement.Brake pads? may have some movement
                                                3rd April 2009, 06:24 AM
			Clunking
					Yes mine has done that for years it is your front bushes on the radius arms check to see if they are tight or you may need to replace them something i did notice on mine when I was rust proofing it was when i sprayed lanolin around under neath i got some on the bushes which causes the rubber to swell and their was no more clunking but i wouldnt recomend doing that all the time.
