                                                4th April 2009, 11:35 AM
			Lift Spacers
					Hi All,
 Wanting kn ow where l can get lift spacers for the front of the Defender? ARB? TJM?
 Using a large steel washer, drilled out to fit the rear. But as the shocker is incolced with front need something a little more 'technical'.
 Looking for about 30mm of lift - just to counter the winch, bar etc.
 Ideas appreciated.
 Mike
 2011 DEFENDER 130
                                                4th April 2009, 06:28 PM
					If you are talking about spring spacers, they are available as a genuine part from Land Rover. ANR something... I can't remember, but I do have a brand new pair in my shed.
                                                4th April 2009, 07:40 PM
 I think that is what l am on about. They just sit at the base of the spring tower and serve to lift the vehicle?
 I assume your are for the front?
 Are you keen to sell them??
 Where you located mate?
 Mike
 2011 DEFENDER 130
                                                4th April 2009, 08:30 PM
                                                #4
					The ones I have are to suit front or rear of a Range Rover Classis / Discovery.
 They should suit the front of a Defender.
 I can't remember exactly how thick they are, but I suspect they are only about 20mm.
 I live in Horsham, but I don't think I will be back there for a month or so.
 I think that Patrol or Landcruiser ones might also suit, but don't quote me on that.
                                                5th April 2009, 06:00 AM
                                                #5
					Thanks for that! I will call ARB and check it out.
 Mike
 2011 DEFENDER 130
