Results 1 to 9 of 9
Thread: 98 Freelander servicing schedule
    Deanslandy Guest
    Hi all,
    Just wondering if anyone could let me know the servicing schedule for a 98 Freelander diesel as in air cleaner,coolant replacement etc.
    Thanks in advance.
    Dean
    Every 10000km
    Change Oil and Filter
    Every 20000km
    Change Fuel Filter
    Check power steering level
    Check gearbox oil level
    Check diff oil level
    Check IRD oil level
    Check brake pads
    Every 40000km
    Change Air Filter
    Check brake shoes
    Every 60,000km
    Change Security system fob batteries
    Change Coolant
    Change Brake Fluid
    Every 80,000km
    Change Timing Belt
    Change Fuel Injection Pump Belt
    Change serpentine (alternator/A/C/Power steering etc) belt
    Every 10 years (may have been changed)
    Replace airbags
    Replace seat belt pretensioners
    This covers the basics
    Deanslandy Guest
    Thanks Gary much appreciated. Gives me something to work off.
    Dean
    Aug 2010
    Albany, WA
    I know it's been a long time - but I'm a bit slow, you know.
    Had the 1998 xeDi for 7 or 8 months now and lot's of stuff has
    happened in that time, such as moving from Tasmania to Southern
    WA. Been doing lots of bits and pieces, but just haven't had the time
    to do a full service. Looking at the Schedules I can't find anything
    about renewing gearbox oil on the PG1 gearbox. Then I read somewhere
    that it is "Filled for Life" - is this kosher? - Garry, your list says "Check
    gearbox oil level" - nothing about renewal.
    Derek
    Quote Originally Posted by vonkprop View Post
    Derek
    Your reading is correct and also applies to the IRD and rear diff - gearbox, IRD and Diff are top up only according the RAVE and Haynes service schedules.
    Interestingly the Getrag manual box in the TD4 requires the oil in the gearbox to be changed every 160,000km bit the IRD and Diff is the same as above.
    I change mine every 50,000km to provide peace of mind.
    Aug 2010
    Albany, WA
    Mmm... my son and I have gone over this a few times - and concluded that I should change it anyway on the basis
    of the fact that we don't know what's in there. Even though we have a reasonably complete service history - and
    most of it by LR that doesn't seem to be an absolute guarantee - on this basis - he (my son) has had a 2002 Defender
    for 6 months now that he only uses sporadically (because he is flying in and out) - and has come to servicing issues
    for his - and trying to hunt down some MTF94 - the LR service guys in Albany say they use something else (Castrol ????).
    So, our only real guarantee that we know what is in there (even if we never change it in the future) - is to change
    it at least the once - then top it up so we know what's there.
    We can get MTF94 from LR in Perth.
    So - the bottom line - change and make up my own schedule
    Thanks Garry
    You will not find Caltex MTF 94
    See this recent thread on R380 gearbox oils.
    http://www.aulro.com/afvb/discovery-...tc-gearbox.htm
    Aug 2010
    Albany, WA
    No that's Texaco - LR in Perth say they have it. We can't find it anywhere else but they get it by the barrel and will sell us some.
    WHat do you use when you do yours?
    Castrol Syntrans works great. Just a bit expensive.
