Results 1 to 8 of 8
Thread: L322 SIDE STEPS
    Feb 2009
    Bondi
    L322 SIDE STEPS
    Hi Everyone
    Just purchased some factory side steps which are used and came with no fitting instructions.
    Do i need to remove the sill cover to access the fixing points ?
    Cheers Paul
    Queensland
    Hi Paul, go to the LR UK web site and you will find the installation instructions for all the add-ons.
    I don’t have the exact web page address but if you have a problem finding it, just post a reply and I’ll go find it.
    Feb 2009
    Bondi
    l322 side steps
    Thanks Drivemaster.
    Just had a look on LRUK,could not find the link you suggested.Would it be possible to e mail the link to me.Much appreciated.
    Regards Paul
    Queensland
    Hi Paul, below is the web address but it has changed a bit since I last used it and I didn’t have much success in downloading anything but see how you go.
    Land Rover Owner Information (WAR00556)
    Feb 2009
    Bondi
    l322 side steps
    Thanks Drivesafe
    Found it first attempt,will be fitting them today.
    Cheers Paul
    May 2003
    On The Road
    It never happened without PICS!
    Jan 2014
    Bundaberg
    Hi Brummy,
    I know this has been a few years since you asked these questions. I am thinking of steps for my L322 so would you be able to tell me about why you got some, and did they do the trick for you. Are there any adverse issues since you have fitted them?
    Thanks in advance
    Manly QLD
    Factory Steps
    Why:
    * Provides a step for little people to get in and out.
    * Provides a step to allow the cleaning of feet when on the beach / mud patch / wherever. Very civilised, all laughs aside they are very handy with kids.
    * Provides protection from rocks / debris flying up the paint work from the front tyres. Just before the steps went on I spent an age cleaning tar off the doors after going through serval kms of fresh road works.
    Downsides:
    * Ground clearance - they are not sliders and I did bend the factory steps on the Disco2 about 12 years ago while hoping rocks up the northern end of Fraser Island. In saying that, they did straighten and they did protect the sill which probably would have coped it.
    * Ground clearance - when the inline fuel pump failed I discovered there's not much room to climb under when off road height is not available (because it wouldn't start).
    * Not sure if I mentioned ground clearance - One of the lads posted a cracker looking set of sliders not long ago that would be easy to extend a little to provide the advantages of steps as well.
    Would I remove them - Only if a nice set of sliders were available. Unless you are serious offroading they are not an issue.
