Results 1 to 10 of 13
Thread: Desktop puzzle
    Adelaide Hills. South Australia
    Desktop puzzle
    Win. XP Pro. SP2.
    A couple of days ago my desktop decided it wanted an ID change & a split personality so decided it liked the 1/5th x 4/5ths look.
    Left side of the screen is the normal XP blue while the 4/5ths on the right decided it wanted to be white.
    Icons move around ok & the Desktop image is partly concealed behind the white.
    The screen now contains the "Do you want to restore your desktop?"
    But that only brings up an I Ex Script Error box "line 65 / Char 1./ Error message about not supporting this action. A url .......... . Do you still want to to continue running script Y/N? Does not do a thing except make that box disappear.
    If I try to follow the url, it peters out before ....... /Application/Microsoft/Internet Explorer/Desktop htt. so I cannot get any further.
    When booting from cold the screen is perfect until the last action, when it slips into 1/5 / 4/5th mode.
    Are the two problems connected & if so what can I do about it/either please.
    Thanks in anticipation
    Go into the Registry editor and change the value of this key
    HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\Desktop\SafeMode\Components\DeskHtmlVersi on
    to zero. Should resolve the issue.
    Thanks. Have done that but still the same. Does that action need a reboot?
    Could well do as the desktop loads at startup
    Thanks DM, that looks like it's sorted. I didn't note the Reg Ed figures down but they were into 3 figures & certainly not 0.
    Just need to sort out the remaining problem of my Active Desktop Recovery Script thingy as I still cannot get past Des, to Applications/Microsoft/Internet Explorer/Desktop htt.
    If only it was another Regedit.
    This is sooooo weird.
    If I right click on the Desktop & select ...
    "Arrange Icons to...................." > "Lock Web Items on Desktop". I get the white screen.
    If I untick "Lock Web Items....." the screen returns to the Win XP Pro blue Desktop.
    Instead of locking the items I will leave them unlocked to eliminate the 'Active Desktop Recovery' Screen.
    I don't know if there is a Techie reason for this but it will do me for now.
    Not sure on this one. Have you Googled the issue?
    You're starting to remind me why I moved over to Mac
    I think it started last week when I took someone's advice to try out Ubuntu & run it as a trial alongside Windoze which one is supposed to be able to do.
    It may have altered the registry & who knows what else? As it turned out, it was such a PITA that I uninstalled it, but it probably left some Reg. alterations behind even though I cleaned out the last bits of files I could find with Revo Uninstaller.
    The old story of "if it seems too good to be true, it probably is" .
    No, DM I haven't Googled it. Letting sleeping Dingoes lie & all that.
    Thanks for your input.
    It definitely sounds registry or config related. Have a look through the startup items in MSCONFIG and see if that turns anything up. Otherwise, I'd go for Google.
    Just had another thought. Try looking through Annoyances.org. I found this with a quick search: Desktop items highlight problem (Windows XP Discussion Forum)
    What's that XP go back thingy?
    Ah, restore points.
    Simon
