Results 1 to 10 of 22
Thread: slotted swivel hubs
    Jan 2008
    Sydney, West
    slotted swivel hubs
    the long weekend provided enough time to get in the shed and play landy. so I wipped the swivel hubs off and slotted the holes. my county has 130mm bumpstop clearance and the castor angle was all wrong, after reading Discowhites fix for the castor correction I thought i would give it a go. I marked out the flange where the new hole had to go and center punched the the new position, I then drilled the holes out starting with a pilot drill then going up 4 drill sizers at a time. I then used a die grinder to join the two holes up. Now to how much to rotate the hub, first measure the curcumfirance of the flange which was 383mm then divide it by 360 degrees,=1.06mm. this measurment is equal to 1 degree. Now stock castor is +3 degrees with approx 70mm bumpstop clearance so that is a differance of 60mm or 2.4" for me. I have read that for every 1/2" of lift you loose 1 degree of castor so multiply 2.4 by 2 and this gives you the degress lost by the lift= 4.8 degrees, take 4.8 from the factory +3 degress and you have -1.8. to correct this you multiply 4.8 degrees by 1.06 to give us the distance to rotate = 5.088mm. so fit the hub and make a referance mark on both flanges on the hub and the axle housing(best done before removing from the vehicle) now fit two bolts on opposing sides not to tight though and use a steel rule to measure your adjustment nip the bolts up and check your measurments again, when happy referance mark the new position on the housing. then continue fitting the cv and hub assembly as per normal.
    Padstow NSW
    nice job!
    ive just done my 2nd set on the ute, be buggered if i can get them to move either
    on the first set i used an angle gauge sitting on the king pin swivell bearing and got it within .5 a degree according to the wheel alignment.
    the set ive just done on the ute i marked and moved 5mm, left the angle gauge at work
    cheers phil
    Darwin
    Hay Lamb, how about you post up a pic of why you have to do this. You mad bastard.
    Check your PM's too
    Jan 2008
    Sydney, West
    thanks discowhite, all went well and I have been out and have check it all and still no movement and I don't think there will be. I moved mine 5mm and it has made so much difference.
    Larn's, what do you mean.
    got some photos for you.
    the nissan is my mates and he has 7inch lift and the county can stay with it for flex , the only time he can go further than me is if he uses his lockers. so I am really happy with that.
    99.87 MB
    Gotta love these axles.
    In the Toyotas they cut the ends and rotate them before rewelding to do the equivilent.
    Slunnie
    Jan 2008
    Sydney, West
    yep very good, very cheap and easy to do as well and you maintain driveline angle, which is lost with corrected arms, I would like cranked arms at the chassis though, can't be to hard to make.
    darwin
    all you need now mate is a isuzu,
    Darwin
    03 disco 2a td5
    93 tdi disco [gone to a better home]
    2003 d2a v8 retired hurt
    1988 k100rs bmw gone
    85 county izuzu [gone to a better home]
    69 series 2a [gone to a better home]
    series 2a [gunnado]
    series 3 [gunnado]
    and the tinny
    Jan 2008
    Sydney, West
    yeah I know a guy who has one as well
    peachey80 Guest
    Hey buddy,
    Nice work indeed !!
    How wondery was yours before you did this ?
    Hey Peachey...
    It's like people whose shoulders dislocate all the time asking someone who has had the op to fix.
    If you're needing to ask the question you need to do it.
    One of the all time best things I did to mine, which has a 2 and a little bit" lift.
    Love your truck BTW.
    cheers, DL
