Results 1 to 6 of 6
Thread: Rattling that dissapears with handbrake?
    pingu Guest
    On my '93 defender 110 I'm getting a relatively loud rattling noise at idle which goes away with a couple hundred RPM. The noise coming from around the center of the body (I think), not quite sure where. The weird thing is, when I pull the handbrake the noise goes away. Pull it softly, the noise just dies down a little but pull it all the way and it goes away entirely.
    Any idea what's rattling about? Thanks in advance.
    probabley something on the output side of the Tcase from a bearing to the front UJ on the rear propshaft.
    checked your exhaust for holes.....? or lose brackets
    Edit: sorry never read post correctly in regards to the handbrake fixing the noise problem when engaged. So probably not what I suggesteed although it wouldn't hurt to check
    Nov 2008
    Usually somewhere
    22.04 MB
    Quote Originally Posted by pingu View Post
    Had a problem of similar noises and remedies. In my early 1984 110 the cable of the handbrake was resting against the underside of the middle seat floor cover. On engaging the handbrake this tensioned up the cable such that it no longer rattled against the cover, Problem gone with a big 'blob' of silicon and replacing the seat floor cover. Unsure if the '93 110s have a similar handbrake set-up. If so, check where the cable goes and what it is resting on.
    Rayngie Guest
    Weird, the rattling in my car always stops just after the handbrake gets out too......
    pingu Guest
    Quote Originally Posted by windsock View Post
    Yes, this was exactly the problem. Repositioning the handbrake cable made the noise go away. Thanks!
