First what is is going into?
I really isn't that hard. as you an use most rover bits to get it going such as getting the right bellhousing and clutch etc and engine mounts. Just use what ever carb set up you like and of course you can get it to run. but why!
The 300tdi is a great motor. if you keep blowing up motors then I bet you blow up the gearbox next with the extra power.
What keeps blowing on the 300tdi. You might be getting it too hot so spend the money on good big intercooler and big exhaust and don't fuel it up too much. it will go well and be more reliable than the big v8 and use way less gas.
