Thread: How to replace rear diff in P38
    NSW Far South Coast
    Anyone know of any sites showing how to remove a rear diff from a P38.
    What do I have to undo at the wheels to move the driveshafts out of the diff splines.
    Unbolt the hub and slide the whole axle hub assembly out.
    This will give the idea: Hub and Wheel Bearing Replacement (Range Rover 4.0/4.6/P38)
    Nov 2006
    narellan, sydney
    Its pretty easy.
    Drain oil,
    remove wheels,
    remove the callipers,
    undo the bolts holding the axle flange on, (theres 4 bolts on the axle tube near the brake calliper bolts)
    remove each axle 3 inches (or completely, it doesnt matter)
    unbolt the tailshaft (2 9/16 ring spanners)
    unbolt the 10 or 12 nuts around the diff center (you can get at them all with a socket apart from the ones behind the vibration mount on the pas side). then the center should just pull out, sometimes it needs a wack with a lump of wood to loosen the rubber glue gasket.
    Andy
    May 2008
    Hi YTT105
    If you embark on this interesting adventure, can I come over to help/watch/learn?
    Paul.
    NSW Far South Coast
    Paul
    I'll certainly let you know when it happens, an extra pair of hands would be most helpfull!
    PM me you phone number and I'll call you.
