Results 1 to 6 of 6
Thread: sway bars
    clean32 is offline AULRO Holiday Reward Points Winner!
    SA, Newton
    sway bars
    Ok i doint have one, but i do have a 125Ltr tank in its place.
    the problem is that when we are loaded up she sways a bit
    so has any one fitted a sway bar mounted to the frount of the dif? or is there any othere possible solutions?
    Preston Melbourne Vic
    I have a 130 with a long range tank and the sway bar actually has extended mounts that allow it to go under the tank. I have noticed the bottom of the tank has some dents in it that I put down to the sway bar possibly contacting it at full articulation.
    To increase stability, i.e cut down on the roll oversteer effect, you need to increase the understeer. Fit a bar to the front, or a bigger bar if you already have one.
    On my 110 I run a front bar from a 130 on long trips, with full roofrack etc. It helps a lot.
    Max P
    Feb 2005
    poly airs
    i like tuskers tip re: sway bar on the front
    Nov 2008
    Usually somewhere
    22.04 MB
    I run a swaybar-less 110 flat deck with poly airs also. They are inside OME 280lb/in rated springs - 755's?. No air or at vacuum for full off-road articulation and about 12-17 psi in them for on-road stability with a ton of firewood on the deck. The flat deck means the load is higher by approx 150mm than a high cap pick up or normal pick up deck. Makes for plenty of those tippy feelings if no air bags inflated.
    SA, Newton
    thanks guys
    its the inital sway only about 5 deg each side she seems to furm up a bit after that, i am puting that down to shocks.
    sway bar is good, i doint know how these are rated? is it just DIA or is there a bit more to this?
    Air bags, i have ARB air onbord so this may make more sence. any idears on costs??
