 Originally Posted by
chris1983rangie
sometimes i see cars on the road doing that!
 could the springs move between the u-bolts, especially if there's no guide pin?
cheers,
chris
 A worn head, or more likely, head broken off, on the centre bolt will allow the axle to move on the spring. Not uncommon, used to see it a lot more, when most cars had leaf springs at least on the rear.  It results from allowing the U-bolts to work loose. Series maintenance instructions include checking the U-bolts every service.
Incidentally, I note in the latest LROI that Dunsfold now have the narrow springs to original spec - for 150pounds each.
