Results 1 to 10 of 11
Thread: Anyone have 15x8 Steel rims on their D1?
    F_U_Z Guest
    Hi Guys,
    First up, It's great to find such a great source of info
    I have read, and read... and read for specific info on fitting 15x8 steel rims with a 30-32" tyre on a D1. I am still not confident that this is an idea that isn't going to cause problems.
    What i am trying to achieve is a better traction tyre without neccessarily doing a suspension lift and or body lift - yet.
    I currently have the factory 16x7 steel rims with a 235x70x16 setup. I'd ideally like to go to a 15x8 with a 30x9.5x15 or 31x10.5x15.
    Does anyone know for sure that this kind of setup is possible without any kind of lift? Exactly how much bigger can i go diameter wise before i will have an issue? I gather if i keep it under control i can avoid any of the gear ration issues too.
    Also, if this has been covered in another thread i have missed please just post a link to it Thanks for you help in advance!
    Jason
    May 2006
    Ulverstone,TAS
    Hi Fuz,
    I got 15 x 8 on my D1.I did have 30x9.5x15 desert duellers on them,but when I put new rubber on them,they're 235x75R15 Mudstar muddies.
    Only done cupla thou on them,but they're so far as good as the dd's.
    Haven't been off-road as yet,but am ichtin to get them dirty.
    disco gazza
    92 disco tdi
    2014 Freelander SE TD4
    2003 Range Rover TD6
    92 disco tdi manual sold
    95 disco tdi auto gone
    Apr 2007
    NW Tassie
    Welcome
    I have and run mickie thompson 31 x 10.5 at's
    Ihave got a lift but run airbags in the rear an 30mm spacer in the front
    Also have a arb bullbar and 10000lb winch.
    30" tyres would fit in standard trim I reckon but I thing they are to wide for the 8" rims
    blaze
    Logan Village area S.E. QLD
    they will fit but VERY close to the brake calliper...
    Mrs ho har
    Series Landy Rescue
    Our FB Page..
    Aug 2008
    Perth, WA
    I currently have 15x8 or 15x7 not sure alloys with 30/9.5/R16 Coopers ST's on them
    They fit fine but I'm changing to 16x7 Steel with 245/75/R16 so my wheels are the same size as a mates disco, Turns out Insurance took issue with the 15's as they weren't standard equipment and wants a stock size on there
    Is there any advantages to 15s rather than 16s ?
    Mar 2007
    South Coast NSW
    G'day, I'm running 15 x 8's with 31 x 10.5's 2 inch lift and the rears still chewed on my rear quater (even coming out of my driveway). Bit of a chop and they're good.
    I'm running standard rear springs in the front, no chopping of the guards, no problem. This may change whe I get around to removing the front sway bar though.
    By the way, also running Bilstien shocks, and the front turrets have been lowered 2 inches, although this doesn't really affect upward travel.
    Warrandyte, vic
    Quote Originally Posted by Distortion View Post
    The advantage that you will get is you will have more sidewall in your tyres for the same height. That means when off road more side wall to flex as you go over obstacles with tyres deflated.
    Even when hard though you will still get some of this flex when on the black top which will detract from handling.
    Eventually you will get to a point where there is too much side wall flexing and your steering becomes too vague. In the tyre sizes discussed here a 15 inch rim would be fine. IMO about 33 inch is the change over point to a 16 inch rim and 37 inch is the change over point to a 17.
    Moruya Heads/Sth. Coast, NSW
    15" tyres are much cheaper to buy than 16's, Regards Frank.
    F_U_Z Guest
    Thanks guys,
    It looks like a 31" tyre will need a lift of some sort on a 15" wheel, but a 30x9.5 will be ok.
    My understanding of the larger sidewall was it created a larger surface area when deflated equating to improved traction. Handling does change but I don't know of any specific guide to measure the difference in ride other than by feel/trial and error. (please correct if otherwise )
    Cheers!
    Jason
    Warrandyte, vic
    When fitting tyres to rims, manufacturers give you a range of recommended rims widths that can be used.
    I like to squeeze the sidewalls in, to fit tyres onto a narrower rim rather than spread them out, to fit a wider rim.
    A tyre on a narrower rim is less likely to fall off the rim at lower pressures. For example I run 34 x 10.5 tyres on a 7 inch rim and have never had problems with tyres falling off rims even at 10 or 12 psi.
    Personally I would not put a 30 x 9.5 on an 8 inch rim as I think the risk of debeading the tyre is too great.
