Hello there!
Without seeing the type of connectors you have, If you have those dodgy automotive crimp connectors, I would remove the plastic insulation on them, crimp them, then solder them, making sure the solder soaks right inside the fitting, then cover with heatshrink tubing. You may end up with 7 amps continuous going through them, and they may get warm, or just loosen up over time.
2.5mm2 is on the lower end of cabling for 80w solar, but will be fine for a shorter run.
Fraser
