Results 1 to 3 of 3
Thread: D2 owners pipe wear warning
    Denmark WA
    Exclamation D2 owners pipe wear warning
    Just out of interest...
    When fitting my pro-vent I found that the breather pipe to the PCV valve on the turbo intake hose had nearly worn through the air-con pipe - the same one that the radiator hose rubs on if not dealt with! Check it out people or you may be out of gas soon!
    Cheers all,
    1974 Military Lightweight Landy --- Some dementia at 50 years old
    2000 Disco series 2 now sadly moved on!
    No5 Trailer joined the fold... Awaiting graduation to road licensed!
    2021 Mazda BT50 or is that DMax?
    porgey Guest
    wear in pipe
    Dave, yes mine was the same had to tie it out of the way.
    Cheers George
    Pennant Hills, Sydney
    also the rubber hose wears out on the left hand engine mount this happened to me luckly it cost nothing for the hose
    disco seriesII mods so far:-bullbar,hyd winch,
    detriot locker,lsd front,C.D.L kit,chipped and bigger intercooler,2" lift,rock sliders, lsd in transfer case, modified auto trans.
    In the event of nuclear war,Disregard this message
