Thread: Hella Flasher unit
    adelaide sa
    Hella Flasher unit
    Hi all, i have a Hella flasher unit, part no 3036, the four terminal type, does anyone know the wiring codes, terminal,nos are c1, c2, 54L, 15X, which wire goes to what ?
    Cheers Andrew
    Central Queensland
    are you sure its the 3036? i've had a look in my hella book and the 3036 is a 5 pin flasher relay
    Central Queensland
    C1: Normally open contacts
    C2: Trailer pilot light
    54L: Direction indicator switch
    15X: Ignition controlled supply
    not being familiar with the relay, i'd take a stab at wiring it like this:
    C1: -ve
    C2: ignore unless you want a lamp on your dash to tell you that you have a trailer
    54L: to the indicator switch, to supply switched -ve to the indicator sircuit
    15X: +ve
    i'd get confirmation on this first though, i'm a lil rusty with wiring up indicator circuits
    adelaide sa
    Yes its of the old kind, the new one is a 5 pin
    Yea, Victoria, Australia
    Is this for the earlier models with Hazard lights? I have a 84 110 and am trying to get my blinkers to blink!
    I have a 2 pin relay at the moment but can't get anything out of it...
    Central Queensland
    the 2 pin type are simply a glorified self resetting circuit breaker...... +ve to one pin, the other pin goes to the flasher circuit, which side is selected by the indicator stalk.....
    Yep gotcha. On the test bench I can make it work but in the socket on the car I get nothing. It will make the hazards flash though.
    Do I need to get myself the proper 4 pin relay or is there a more common unit that will work?
    Central Queensland
    what was standard in the 1984 110? if it came standard with a 4 pin flasher relay, you need to replace it with another one
    i'll hunt down my bosch cattledog and see if i can find the right one for you
    Well I pinched the relay out of the falcon. Its a 3 pin flasher can. Anyway with process of elimination I worked out the blinkers do work, its just the column switch doesnt. I made a bridge wire for the socket in the loom and it all works. The hazards also work. Its a brand new switch!!!
    Swear, yell, throw, angry, grrrr.
    Quote Originally Posted by Sprint View Post
    Yeah a four pin. From what I can deduct the fourth wire is for the dashboard light to say a trailer is connected.
    Im up for another switch or take this one back...
