Thread: EAS Piping
    Seaford Vic
    EAS Piping
    Hi Guys
    Tonight my 2001 P38A developed a slow leak in the R/H/F EAS plastic/nylon Pipe just under the battery box,
    can anybody advise where to obtain an aftermarket replacement unit ie "Purple Pig" etc or what specs the hose should be, it looks about 6mm thick wall section to be rated at 150+ PSI ?? is this correct...
    or is it better to just get original parts ?????
    Ps I'll change my avatar soon as I get a pic of the new wagon
    Nov 2006
    narellan, sydney
    Theyre just 6mm nylon airhose, it only costs a few dollars per metre, sometimes cheaper. It is all rated to above 150psi. Just cable tie it where it wont rub on anything (hot or cold). If you want a genuine one though, pm me your address and i will send you one down next week.
    Andy
    Seaford Vic
    Thanks Andy,
    I'll try to get some from Purple Pig on monday, if not available i'll PM you next week.
    Thanks again
    Quote Originally Posted by westy View Post
    Hi Guys
    Go to your local landy shop and buy a hose to hose joiner. I dont know the official name for it. They are used to join the hose if you get a leak. Simply cut the hose removing the bit with the leak in it, and plug the hose ends into the joiner. Quick and simple. Lasts ages, hasnt failed me yet (4 years).
    Buy 2 just in case and keep spare in glove box.
    2015 Defender 110
    May 2008
    or you can get 15m of the stuff from Rover Renovations for USD30 - see here
    6mm Airline, 15m
    Quote Originally Posted by karlz View Post
    P/N STC8580 Repair Adaptor or Repair Connector
    Seaford Vic
    Thanks everyone for your help,
    As it turns out the car was in at "Ritters" yesterday for some repair work and they fixed the leak (fitted a new inline joiner) free of charge, the guys at "Ritters" are a great bunch of blokes and go out of their way to help you.
