Results 1 to 10 of 13
Thread: Slow Height Adjustment and Compressor Overheating
    WazzaACT Guest
    Has anyone struck this problem. When I attempt to set off road height the vehicle only rises slowly and a warning shows on the system panel. If a try a few times it shows a compressor overheated warning.
    Melbourne, mostly
    Normal after repeated changes of suspension height. But how many times over what period of time? If it's the first time there is a fault, problem compressor, leak somewhere.
    Nedlands, WA
    The compressor will go into a reduced operation mode if it starts overheating. But that usually only happens after lots of up and down.
    If it's happening every day, it could be either that the compressor is on the way out or there's a leak in the system somewhere.
    What MY is your car?
    Nedlands, WA
    Damn! I didn't type fast enough!
    WazzaACT Guest
    The car is MY07 and it happens after 2 or 3 attempts
    Nedlands, WA
    If you go up and down in quick succession, you may get this message and the car will only rise slowly. The compressor cannot fill the tank quickly enough with lots of rapid changes in height, so it tries to work harder. It has a temp sensor which feeds back to the ecu which in turn reduces the operation of the compressor to protect it.
    If you're going from Access to Off Road and back again 2 or more times in quick succession, this is normal. But if you're only doing it once, it's not.
    Melbourne, mostly
    Nedlands, WA
    Sydney, Australia
    If you have been in mud you may want to check your compressor housing.
    They can fill with mud and prevent the compressor from cooling.
    Jan 2008
    That happened to me last week aswell when i was washing the car, I lowered it to make it easier to wash the top and raised it later to wash the wheels and inside the arches, must have been at least an hour in between.
    I have also since then had the suspension warning light come on several times for no apparant reason, allowing only normal ride height to be selected, I switch the car off and it clears for a few days.
    Also my airbag light was doing the same last month but has since stopped.
    Might be worth a trip to landrover.
    G
    2005 V8 HSE
