Originally Posted by
Mundy
JB, there are a number of threads relating to this issue with good ideas and photos of where to fit a compressor and second battery and its worth searching. Not sure what engine you have but if a TD5 following comments also apply.
If you want to fit a second battery under the bonnet with either an ARB or Pirahna battery tray (former is better value for money), you won't really have roon for compressor too. Alternative suggested locations for the second battery are under the car on LHS where the std LR compressor is fitted (assuming you also don't have air suspension), or in rear panier if you have a 5 seater. Alternatives for a compressor are in the space behind the air vents at rear, in space behind head light or, as suggested by Cucinadio, using a portable one.
If you have a 5 seater, my preference is for using the ARB tray to mount the compressor under the bonnet and mount the second battery in one of the rear paniers, mainly because of the battery. The largest battery you'll get under the bonnet is a 55Ah (using the standard trays) whereas you can put a much larger one in the rear, say a 100Ah. Heat under the bonnet is also a killer for the battery IMHO.
Mundy
This is true if you use those trays, but if you make your own tray, you can fit a battery the size of an N70, like this
I'm putting my compressor in a section I made when building my drawers.
If I didn't have this place I would put the compressor in one of the rear panniers, this way it's away from the heat of the turbo and has easy access out the back door.
Here is where mine will go.
Baz.
Cheers Baz.
2007 BMW R1200GS
