I like the ETC too. Does this also turn off the ABS. I had a scare on a gravel mountain road once.Just skipped over the top of the gravel - Yikes.
OK Puma owners...
In the Td5, which also has the Wabco-D ABS controller, the TC could be disabled at start up as follows according to the workshop manual.
"TC can be disabled by operating the brake pedal ten times within ten seconds, when the ignition is turned on. TC will be re-activated when the ignition is turned off then on again."
So has anyone tried this?
Personally I like TC off-road but I'm curious if this applies to the Puma
hmmmm, i dont know i dont have a puma BUT YOU DO
cheers phil
 YarnMaster
						YarnMaster
						ohhh derrrrrr
cheers phil
I'll have to give a go if it ever stops raining. Just thought someone might have tried it already.
come on!! whats some water between friends
the suspense is killing me
cheers phil
I'm with you Phil
Derek..... how else are you going to tell if the TC is off?
Water + Dirt = Mud ....ipso facto: loss of traction
Mahn England
Ex 300Tdi Disco:
he works in gove earns a motsa has all the latest and most expensive toys and cant afford a shed or a carport
whats the go with that...very un australian
cheers phil
