Results 1 to 10 of 14
Thread: My First Mod - 2 inch lift
    Jan 2008
    Grange, Adelaide
    Just had my first modification completed and am really pleased with the result.
    A 2 inch lift on my SLS equipped D2.
    Includes Bilstein shocks front and rear, king springs on front and the usual SLS height extenders etc. Also now has a new Bilstein steering damper and it drives fantastically.
    Bit the bullet and replaced the head gaskets, radiator, viscous fan, drivers door lock actuator and the indicator switch.
    Nov 2007
    lift
    hey mate i put this kit on mine few months ago, just wondering what were the sizes of the shocks front and rear no body can give me a straight answer, and did the new dampner make a difference?
    Jul 2008
    Eastern Suburbs Mexico Vic
    Quote Originally Posted by simonl8353 View Post
    Looks great Simon,
    From my other post, I am interested to find out what Bilstein Shocks you have, as the Aust distributor for Bilsteins indicate they do not do a SLS shock, and any Bilstein shock on a SLS D2 voids it's warranty.
    The distributor, who is a friend of a friend is interested to know what we are all running on our Disco's as they will look at bringing in the right shocks to Aus if they can find out which ones they are.
    They will be following up with Germany to see if the can assist.
    Currently they have the following:
    Fronts BE56046
    Rears BE56047
    However cannot recognise:
    Fronts F4-BE5-B994-MO
    Rears F4-BE5-B995-MO
    Which are supposedly the 2 inch lift Bilsteins others are running.
    Like yourself I am looking at King Springs as well. I have recently heard mixed reports on the dobsons, hence I am looking at options.
    JB.
    Jan 2008
    Grange, Adelaide
    Fronts are (Bilstein) F4-BE5-B994-MO, Rears are F4-BE5-B995-MO
    Steering Damper is F4-BE3-A580-HO.
    The car drives extremly well.
    AMV did the fitting and provide 12 a month warranty.
    McDisco Guest
    Nice one Simon! Thats looking nice and high now!
    Angus
    Jul 2008
    Thanks Simon, much appreciated.
    Tried to send PM Mail box Full!
    Jan 2008
    Grange, Adelaide
    Quote Originally Posted by JayBee75 View Post
    PM inbox now ok, I deleted a bunch of old stuff. Its something to do with my subsciption payment failing which has now limited the number of PM's I can store.
    Hope to sort out the subscription thing asap.
    Aug 2009
    Brisbane, Sunshine Coast, Gladstone, QLD
    I have been looking at excatly the same setup with the extended Billstein shocks and 50mm extended King Springs.
    With this setup does the spring stay in its seat under full drop (the Billstein supplier says they wont) and do you need to space the front crossmember and extend any brake lines etc.
    Chris
    May 2003
    On The Road
    WOW!
    Thats HIGH!
    would be interested in prices on engine works,,
    will PM.
    Braeside, Vic
    well done,
    Zac same set up as mine.
    I can see some bigger rubber coming your way soon
