You'd need to check:
PCD -- pitch circle diameter. The size of a circle made through the centre of each stud. D3 is 120mm, written as 5/120 as it has 5 studs. Don't know about FFRRs.
Load rating. Forget what D3 is, think it's 960kg min.
Stud diameter.
As for the offset, yes that's out, but not enough to be concerned about.
The rim diameter is ok for a V8 D3, min 18s on those.
