Results 1 to 10 of 12
Thread: Chassis Repair Tips
    Jul 2007
    Chassis Repair Tips
    finally had a leave pass from the mrs to go and work on the nome (the trayback sitting in the garden the last 6 months) today. I pulled the tray off to start cleaning it up and found the rear x member needs a bit of attention and one of the rear spring out riggers will need replacing. Am I best to get a new one bent up or what will it set us back for a replacement? Also whats the best method to remove the rear x member without desroying every thing? Any other tips?
    Oct 2007
    JUST NORTH OF COFFS HARBOUR NSW
    Quote Originally Posted by Randylandy View Post
    We are about to remove the rear cross member on the county, it's welded on i'm not shore about s3's though.
    We are planning on cutting it off with a plasma cutter, if you could get in there with those extra thin grinder blades they might do most of it
    otherwise i would use an oxy
    CHEERS TIM.
    Jun 2007
    If you don't mind a bit of work and you want a neat job you can grind the welds and remove it with no problem at all.
    I swear by 1mm 5 inch grinder discs. 3 will remove the cross memeber from the back of a series and you dont have to worry about the plasma blowing holes when it hits chunks of crud or thin spots.
    you have to be smart about when you change the discs tho as theres a couple of bits you need to hit when the disc is nearly full size or you wont complete the cut.
    IF you can find them get the .5mm wheels they make using a 1mm wheel look like using a grind stone but be warned they take absolutely NO side loading or off axis torquing.
    Jul 2007
    thanks I tried the .5mm ones yesterday for the first time they are awsome also found out about the side load pretty quickley lol
    Jul 2007
    ok have finally managed to cut all the crap that people have welded on the rear x member over the years to strengthen it up and think I shoud build my own x member an extra strong one so I can mount some decent recovery points and tow hitch the old design just looks too flimsey. Anyone built there own any chance of some pics?
    Adelaide Hills - SA
    A bloke called "The Chisolm" built a rear cross memeber from scratch. You could try PMing him, and seeing if he still has the photos etc (he sent them to a few people). The link is here:
    Rear Crossmember - Replace or patch (properly)
    Also there is another link to his work, but the pictures are all gone:
    Trans Tasman Land Rover Series 1 Register Forum • View topic - Making a rear crossmember
    HTH
    David
    Boonah, QLD
    Totally agree, nothing beats an angle grinder. I removed my rear crossmember and some of the rails this way. I was lucky in that i already had a new rear crossmember plus sleves to sleve it onto the chassis when i bought the car.
    It passed RWC so it can't be to bad haha
    Oct 2007
    When we get a fuel tank for the county (a week or two) we'll be getting stuck into making a new rear x member from scratch, plans are to build a whole new toung stile tow-bar built in up hi so we don't hit it anymore, it will be very strong, bolted on not welded and maybe getting it Hot gal dipped
    also have some strong recovery points some where
    I'll start a thread when we get into it
    Jul 2007
    Awsome, have also sent chrisholm a plea for his article. Please keep us posted with your design (guess I should also take some pics to show those interested). So far i have hacked off the old x member (got to love the 9"grinder) and have plated up the ends of the left chassis rail as they where rusted through as well on the bottom I will do the other side in next day or so.
