Has anyone had this problem or know of it?
Has any one had this problem or repalced lock cable ?
I don't know if I should say it's a common problem but I've seen quite a few through work. It's usually the cable end that breaks.
UK problem has been corosion of the latch (aluminium) due to water ingress (and salt)
Remove the boot and have a look.
Actuator Cable Broke Recently. Almost $400 to repair including replacing the broken trim panel so access could be gained inside the tail gate.
Was told that I was lucky that it hasn't happened before this, fairly common.
Discomaniac
I have seen it a few times. Trim destroyed for access. Both times I saw it warranty paid...
Mine was replaced - out of waranty. They managed to do it without destroying the trim. Said that they had done many that way...
Hi Scouse,
Which is cheaper, 1 hr of dealer time, or a new trim?
Best Wishes,
Peter
Ouch
