Results 1 to 10 of 12
Thread: 300 Tdi output
    May 2009
    300 Tdi output
    Just when you are happy with the way the old girl is going............Pulled myself away from the screen at midnight after reading about how to power up the 300. I remember that the pump had been fiddled with.....but when reading about some other vehicles got me thinking. Then i found the dyno sheet.......
    Is it any good, 47kw is not alot but it goes OK.
    any thoughts.
    Pomm
    Attached Files Attached Files
    Safety Bay
    Mines got 65hp on diesel and 77 on D/gas.Thats at the wheels running 33's. Pat
    Feb 2005
    i have attached my dyno printout
    May 2009
    Who did the work for you............at a guess my 47kw is about 62hp. Another 30 would be nice.
    pomm
    Feb 2005
    mr automotive did the tweak.......i used a dyno shop in sandgate, i was not overly happy with the dyno shop, i hope the figures are correct
    95bhp at the wheels woohoo
    NSW , Pennant Hills
    Pommy66;
    I had mine tweeked and Dynoed at Graeme Coopers ,49kw at the wheels. (Safely) ,I recall phillipC saying ,they very occasionally get a "Rocket Ships" from the Factory that when properly tuned squeezes 63-65 kw out at the wheels.
    May 2009
    I will have a chat to Warren and get him to take it for a run. Cleaned to cooler and lines out today, also checked the stopes and cable tension etc etc.
    I will give it a thrash tomorrow.
    I have just got rid of a 4.2 wagon GU....after pump fiddle and a bit of boost (15psi) made 115hp in 2wd.
    pomm
    Safety Bay
    I might have to tweek my pump!!. Pat
    Oct 2008
    Northern Melb.
    I got a power upgrade straight after getting my 96 300tdi disco. Cost a fortune, but was worth it. I went from 49kw to 61kw at wheels on standard tyres. The fuel pump was already cranked up from one of the previous owners, but that is not recommended. They had to turn the fuel down, and still got more power. I was told standard they dyno around 42ish kw
    Since then i have also removed the muffler, and now have a straight through exhaust, which gave it a little bit more as well.
    I want to get an upsized intercooler and maybe look into turbo upgrade/boost but dont think $$$ spent will be worth it for a couple more kws, it drives nice enough anyway.
    That may change when i put 35's on it, currently I am running 33" muddies and it still drives ok, keeps up with all traffic easily and cruises well on the highway.
    Some reference kws -
    NA 2.8l hilux 34.9kw, patrol turbo strapped on it got 55.5, he blew that up, got a 3.0l turbo got 65.7
    so i am happy with my little 2.5 with tiny turbo getting 61 hehe
    Aug 2008
    Victor Harbor SA
    As I've mentioned in other threads I purchase a 98 TDi, had an upgraded intercooler fitted, then dynoed.
    Result:- Went from 52kW (pretty respectable anyway) to 70.3 kW (or 94.2HP).
    I think it's a little overcranked, and worry about high egt's if I plant the foot for too long, so am planning to get it wound back just a tad at the next service.
    But as is she goes like a rocket, that's for sure.
