Do a search for exhaust, alot of people have made modifications, but nearly always keep one muffler.
What size should i go ? (300Tdi Exhaust)
You can always remove the mufflers if you want to, but the performance appears to be not really increased even if you do.
Removing one and or both mufflers generally gets the turbo spinning earlier, so there is a slight power increase to be had.
But it is a big trade off. From what I've read the drone at highway speed is the biggest problem. Remove one muffler and its fine, but go straight through and its nearly unbearable.
