Results 1 to 10 of 15
Thread: Home made Part time solar hot water
    Apr 2007
    NW Tassie
    Would it work
    Been think of getting 20m of 5/8 copper pipe and bending /\/\/\/\/\/\/\/\/\/, well some thing like that, fitting a relief valve and mounting on my roof to get the sun, roof is brown colorbond. My thoughts are to feed the high pressure cold water in one end and out the other into the electric hot water system (return pipe would need to be insulated). Surely by feeding hotter water into the electric hot water system it would not operated the element as often thus making it cheaper
    Whats your thoughts
    blaze
    Adelaide - Torrens Park
    Sounds reasonable to me.
    Adelaide Hills - SA
    Good idea, as long as you are using the hot water during the day.
    Normanhurst, NSW
    A friend of mine had an outdoor hot tub - simply circulated the water through multiple coils of black poly pipe by natural convection, Didn't require any additional heating at all.
    Roger
    May 2006
    Carlton, Melbourne
    As said above, it would only help if you are using the water during sunny weather.
    if your system is mains pressure, there may be a drop in the flow rate because of the extra pipe.
    I hate to say it, but it would really only provide a few litres of hot water each time, then the pipes would cool, and the water going into the heater would be only slightly warmer than the supply.
    you really need the water to be constantly circulating to keep taking the heat away as it flows through the system.
    Fraser
    Apr 2007
    NW Tassie
    what if I was to use 20 to 30 meter of 1" polly pipe (maybe a roll still coiled up), dont know how to work the volume of the pipe out but it must be a bit. I reckon a shower would only use 30- 40L of hot water
    have to think some more but I think it may have some merit.
    blaze
    Normanhurst, NSW
    Quote Originally Posted by bblaze View Post
    blaze
    See post #4 this thread.
    Roger
    May 2008
    Bundaberg Qld
    30 mts of 1" poly would hold a bit under 15 lts. would be better if you could circulate a larger qty of water during the heat of the day and store that to feed your mains system. The idea has a few issues to be resolved, but a good concept.
    Paul
    if you can get a clean one....
    put an lpg tank horizontally on the roof.
    set it up like a convection tank with your coil of copper or mains rated poly pipe.
    Feed the cold water in at the bottom and the hot water out at the top of the tank.
    Or just install a solar hot water system.
    SA, Newton
    a few years ago i chucked 30 meters of green garden hose on the roof, it worked well, even at night the water is not as cold as the water coming out of the ground
