Results 1 to 10 of 11
Thread: Killing the bug
    SA, Newton
    Killing the bug
    Ok getting a bit GGGRRRR here
    my Tank has the diesel bug, first i droped some petrol in there to kill it off, then some Bug killer ( exspencive) but its back with avengence. i hate cleaning the little filter on the pump all the time ( every 500klm)
    any ideas??
    Oct 2003
    Gold Coast, Qld.
    well i'm lost... diesel bug?
    RAAF Tactical 200184 & 200168
    SA, Newton
    Quote Originally Posted by Outlaw View Post
    its like a stringy mold that lives in diesel
    Drain, flush, replace filters, fill with clean diesel. If you're feeling brave filter the old diesel and feed it back in again.
    Or so I was told.
    Simon
    Mar 2007
    South Arm, Tasmania
    I've only ever cleaned it out of large fuel tanks for a powerhouse on a minesite up north. BP in Port Hedland got it a few years back and infected most of the Pilbara.
    We drained the tanks and then got inside with a high pressure steam cleaner.
    Dunno how you'd apply that technology to a vehicle's fuel tank though.
    I see you're in SA - never heard of anyone getting it that far south. I thought it was mainly a northern Aus, mostly wet season thing.
    Cheers .........
    BMKAL
    Ahh diesel SNOT.
    grows anywhere there is a diesel/water interface and a little warmth.
    once youve got it youve had it especially if you have plastic or rubber bits in the fuel system
    drain everything, flush everything with metho and disinfectant then dry agressively, DONT reuse the old fuel and DONT put it in anything you might one day use as a fuel container.
    Jul 2007
    Nambour QLD
    I was told once to put a block of camphor in my tank to prevent it. Don't know if it stops it once it's in there. It does remind me to put one in before I get it.
    Sorrento Victoria
    Do you recommend removing the tank and clean out too?
    Ahh diesel SNOT.
    Jun 2008
    The new Gold Coast, after ocean rises,Queensland
    I think it's called cladysporus resin....Blknight?
    Military aviation fuel has additive called FS11.
    I'm just thinking if you can get some Mil Avtur from someone and flush with it.
    If you know anyone in miltary aviation you should be able to get your hands on some easily....it gets thrown away by the hundreds of litres.
    Correct me if I'm wrong Blknight.
    Den.
    Back down the hill.
    Amazing products that really work.
    Cost Effective Maintenance - Home
