Results 1 to 10 of 17
Thread: I cant get rid of the bloody ding ding!!
    McDisco Guest
    Hey All
    A while ago I changed some of my BCU settings for single press entry and a few other things. I also fiddled with the seat belt warnings. Now I have the 5-6 chime when I turn the ignition on...and its annoying the hell out of me.
    It used to not chime at all. I had thought that the programming of the Nanocom was wrong as it had a 'buckled' and 'fastened' option which I thought were the same, but they are not as I tried my mechanic testbook system and his was the same.
    I have tried modifying other settings but cant get the chimes to go away...any ideas?! Anyone else have the same thouhts?
    Angus
    May 2008
    Northern Beaches, Sydney
    Try this:
    SEAT BELT WARNING SOUND = timed
    SEAT BELT WARNING = timed
    KEY IN WARNING = disabled
    ...works for me
    McDisco Guest
    Thanks crossy. Pretty sure I have tried that but will try again.
    Angus
    Long shot here Angus but give it a go.
    You had problems loading the latest firmware..yes?
    One of the fixes of the 2.04 firmware was the write to BCU unit. It used to come up with an error - 'Unable to communicate' and then say 'write successful'
    Reload the firmware and then take it from there. Worth a long shot.
    McDisco Guest
    Thanks mate, but I have had the problem since before the 2.04 firmware. Serves me rigt for fiddling with it in the first place!
    Bacchus Marsh Vic.
    Quote Originally Posted by McDisco View Post
    Hey All
    Angus
    How did you go Angus?
    Mines doing the same, nearly used to the chimes now
    Still, it would be good to get rid of it.
    Cheers, Kyle
    The Good Oil.
    When did you last visit?
    Bracken Ridge, Qld
    My Defender doesn;t chime at all !
    gone
    1993 Defender 110 ute "Doris"
    1996 Discovery 1
    current
    May 2009
    Try To load the Latest Firmware V2.05
    It's more stable
    Good Luck
    99.87 MB
    Find the chime speaker and cut the wires.
    Slunnie
    Apr 2007
    I am lost
    AWESOME
