Results 1 to 2 of 2
Thread: Hydraulic Jack - repairing and rebuilding
    Thanks to Blknight.aus for this comprehensive tutorial.
    http://www.aulro.com/afvb/projects-t...te-images.html
    Time saver.
    Heres the thing in PDF format, Kudos to p38arover for the conversion.
    not mentioned in the thing is what oil to use.
    Technically you should be using a light hydraulic single viscosity oil. In reality any light engine oil will do the trick and I usually use a 15/40wt oil. Non synthetic is fine.
    http://www.aulro.com/afvb/attachment...1&d=1161091393
    Cheers.
    Farey.
