Barry from Hytuff engineering took over the production of the MD Axles
and MR Automotive do the Rock crawler gears , track rods , not sure about the MD lockers. that 's about all I know.
Im a bit behind the times but who ended up buying maxi drive? Did they buy all? Are they going to continue making all?
I believe Hi Tuff and makin the axles, not sure about the centres
Hi-Tough Engineering
U3/7 Ryecroft St
Carrara Qld 4211
(07) 5530 4123
thanks very much for that![]()
no one took over maxi he let the name die.....and sold of plans to MR like said above and barry that used to work with him makes the axles under a new name hytuff
I purchased the Hydraulic PTO pump etc from MR as well.
Regards,
PeterW
U3/7 Ryecroft St
Carrara Qld 4211
(07) 5530 4123
Sweet my neck of the woods![]()
I have the last set Mal did here for my RangieHe was a great engineer and improviser in his time. Not very likely Barry from HTE
will get involved in the Rover lockers last time I spoke to him but possible some one else may. How ever may do sals. I can't say much as I am a supplier of HT (Rover only as no one else will do them) around here and AFAIK not official yetFor now I supply ARB lockers and use Hi-Tough axles
I would not use the ARB if Maxi were still going.
Tony
