Results 1 to 10 of 18
Thread: data transfer from computer to computer
    99.87 MB
    hello IT savvie comroads.
    I've got a laptop that has no music and a PC that has about 30g of music. Does anybody know of any efficent way of transfering the music across by any chance.
    I have a multiple port modem if thats any help, or I can probably plug the 2 computers in together with data cables if that works also.
    Slunnie
    Do you have Firewire on both, you can then network them?
    The simplest is a descent sized memory stick or USB hard drive though.
    99.87 MB
    I'm not sure to be honest.
    I probably can just save it all to an external HDD and then transfer that way, it just seemed like double handling.
    Slunnie
    That is how I would do it if both computers are working. There will be more direct methods, but almost certainly these will involve a lot more messing about!
    if they are on the same OS and both have a network port you can do one of 2 things
    1. setup a mini network from behind the modem using the modem as a hub (assuming it supports it, mine does)
    2. grab an ethernet crossover cable and setup an adhoc network then just share the files across.
    99.87 MB
    Thanks for this fellows. I'll give that a go Dave and see what happens otherwise just copy it to the EHDD and then again onto the Laptop.
    Slunnie
    richard4u2 Guest
    i think vista has a build it programe for doing that sort of thing
    99.87 MB
    Quote Originally Posted by richard4u2 View Post
    Hopefully! The pc is vista, but the laptop is XP
    Slunnie
    The External HDD will definitely be the easiest.
    Vista and XP both have the ability to network by firewire or cross over ethernet PC to PC. The modem sounds like its a 4 port router or switch so you could use it too and that would be easier than a single cable to set up. But if it was me I'd be going the HDD for 30GB of data.
    Either plug both computers into the modem with ethernet cables, or go via hdd.
    I tried to do much the same a couple of days ago over the network and it was going to take a lot of hours.
    HDD should be faster transfer than network - 480mbps compared to 100mbps.
