Results 1 to 10 of 27
Thread: What is the air-speed velocity of an unladen swallow?
    There's enough other silly questions floating around at present.
    I'm sure someone else will get the reference
    Perth, WA
    You'll have to ask the King, no doubt he will want to know if it's an Africian or European Swallow.
    Tim
    May 2006
    Carlton, Melbourne
    Is that an African swallow or a European swallow?
    167Kmh?
    Melrose SA
    Do you people know nothing 167.2 Kmh
    Oh, and don't do the image search.
    WA
    With or without a coconut (tied to a piece of string held under the dorsal guiding feathers of course)?
    or, is it a ba swallow?
    now which do you want,
    airspeed or velocity?
    airspeed is pretty straight forward, oh well, it does get confusing when we want 'true airspeed'
    but velocity?
    in relation to what,
    still air?
    ground speed?
    which velocity are we thinking here?
    and 'unladen swallow' - what does that mean?
    ie; has the 'welcome swallow' dumped on takeoff, and what is it's unladen weight?
    if a' ba swallow' then we need to know empty weight and max gross, fuel and pax weights and luggage, and to determine 'unladen weight' and still be able to fly it we also need to know the minimum fuel load and intended flight distance and also the pilot's 'actual' weight, then we have to determine if the flight can be conducted legally using the minimum parameters.
    i'll just go and put out the seed for the mornings bird visitors.
    Safe Travels
    harry
    Quote Originally Posted by cooper View Post
    An unladen swallow is basically an air gulp,or the preliminary to a burp.
    LMFAO....
    Logan Village area S.E. QLD
    LMFAO....
    I am there with you girl
    Mrs ho har
    Series Landy Rescue
    Our FB Page..
