Does the check engine light come on? If the ECU detects a fault it can increase revs at idle to compensate.
If the check engine light does not come on then the ECU is not detecting a fault so it thinks that things are normal so I would be looking at the throttle sensor attached the accelerator pedal as it may be sending a high reading to the ECU. Applying the brakes and clutch sends a signal to the ECU that the car is going to slow and cuts back fuelling.
