Results 1 to 10 of 26
Thread: test book dongle
    May 2009
    a
    test book dongle
    Test book dongle schematics and obd2. have obd2 software & rave software also.
    Will make a few if any is interested or make your own as per drawings.
    Have attached.
    Dont know if attachment worked.
    May 2009
    a
    Can anyone tell me how to check attachment. never used before, in forum.
    Did you use the Manage Attachments button?
    May 2009
    a
    Attached using attachment butoon uploaded and closed nothing happens. Trying on other computor with word not microsoft works word processor. test book obd2.doc does this work.
    Dunno what you are doing but if you have an image in a Word .doc file, the file will be huge and will not upload. It has to be under 195kb in size. Convert the file to a PDF before uploading.
    May 2009
    a
    attachment is their and opens.
    Capalaba.Q.L.D.
    yep,it works
    Quote Originally Posted by peacey View Post
    So what does it actually do?
    Does it interface a PC with Testbook software to the OBD2 port?
    Does it allow access to all features that Testbook would do?
    May 2009
    a
    With test book you can turn things off/on reset codes use it to raise lower turn on/off compressor on eas reset climate controls use it to test each component for fuction, runnig with test book software via pc. You can (on p38) to turn on heated seat fuction, all needed is a switch. It is like having the dealers test equipment at home/on board.
    Interesting. I have the T4 software and a BlackBox Solutions Faultmate MSV and would like to try one of your interfaces with a view to telling others on the RangeRovers.net forum.
    You mention making them available - I'm an electronics tech and could build one. Do you have a PCB available?
