Thread: Modification to dedicated LPG....
    Oct 2008
    Hi Guys/Girls.
    I have a 87 RR with dual fuel. When I bought the car it was not running properly on petrol. It would crank over for a second and then switch to gas. No problem for me. I was told by RAA today that it has a delay system so it starts on petrol and then quickly changes over.
    I just stuffed my second fuel pump and was wondering if anyone has been in a similar situation and just modified it to LPG only. RAA say it can be done but others say its a big no, no!.
    Can I somehow by-pass the delay and AFM?
    Any tips/tricks? I really hate the idea of buying fuel pumps every few months!
    Crafers West South Australia
    Hi, you will need a safety cut-out from your LPG fitter. Remove your petrol start switch system and wire in a plain change-over switch. Then you need the safety cut-out to stop the LPG from flowing on when you stall. If you are lazy you can prop open the AFM with a small bolt threaded through the side, holding the door open (you can remove it to regain petrol mode). A piece of 3" exhaust pipe works too. Also you can buy a VN-VS V6 commodore fuel pump and fit it , only around $80 trade, or second hand. Remember to clean out your old fuel if you do. Cheers
    Oct 2008
    Thanks for the info! I just went down to the local mechanic and suggested this approach. He said that is a good plan and could do it for $150 and it will take a few hours. Cheers!
    St Helena,Melbourne
    4.28 MB
    You shouldnt be going thru pumps like that, does the pump run continuously even when on gas ? If so you need to wire it so the pump has no power when you switch to gas.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Oct 2008
    Yep, the pump USED to run while using gas. I am having it run on dedicated LPG on friday so no more problems with pumps. Next will be a larger LPG tank for the trips away!
    Thanks!
    St Helena,Melbourne
    4.28 MB
    Personally i would keep it dual fuel and get it working properly so you get a better range with combined fuel, i've had 2 dual fuel rangies and could get about 800+ k's with both.
    1974 VW Kombi bus
    Oct 2008
    I would rather that too but new injectors (they are stuffed) plus another fuel pump just for starters seems like a big PIA. I like the idea of a simple set-up on gas. I could always change it back to dual fuel if I need to at a later date.....
