Just a point - it is not the IRD that causes tyre wear - it is a failed VC that causes the tyre issues because of transmission windup. Likewise it is the failed VC that causes the IRD to fail. It is the gearing of the IRD that causes the VC to fail - a somewhat circular process.
So if the VC is good - it is unlikely the bearing noise is coming from then iRD.
The noise could be coming from anywhere - I would check - wheel bearings, UJs and VC bearings first - then look for the hard stuff - though unlikey the CV on the propshaft may be an issue.
