Results 1 to 6 of 6
Thread: Where to put the second spare tyre............
    May 2009
    West Gippsland - Victoria
    Carrying a second spare tyre is a pretty good idea if you venture off the beaten track. I've never actually needed a second spare , but the day I don't carry one, well you know what will happen .
    But where do you put it. It takes up too much room in the car, and if you carry it externally you need an expensive roof rack with all of its inherent disadvantages. Poor fuel consumption, wind noise, increased height.
    What I need here is a plan C and this is what I've come up with.
    I need a second spare tyre not a second spare rim, so ditch the rim. I carry tyre pliers, tube, plugs etc so I can change a tyre if need be. I'll carry the spare tyre with the spare wheel. I reckon the bracket's strong enough but if I can transfer a little of the weight off the carrier I'll be even better off. The existing spare when new just rubs on the rear bumper (255/70 as opposed to 255/65), so I'll pack the bumper to take it up a bit tighter.
    Before (note the rub marks)
    After
    Nothing like a bit of conveyor belt rubber and a couple of pop rivets.
    Then drill a 16mm hole in the centre (close ) of the spare wheel carrier and fit a piece of high tensile threaded bar with a nut either side. Anyone who does concrete panels will recognise these bits. The bar is grade 80 steel and as strong as hell.
    You do the nut(s) up with a hammer by belting the lugs. There's no way it's going to come undone.
    Next cut a piece of aluminium road sign, um................err, scrap 2mm plate, in my case 440mm in diameter and glue and pop rivet it to a piece of 6mm marine ply 400mm in diameter. The ply centres the tyre and the metal disc pulls it in. Note the washers on the pop rivets where it pulls up on the wood.
    Cut a smaller disc for reinforcing on the back, a couple more pop rivets and cut a 16mm hole in the centre.
    Screwed another nut on the shaft with its flat outwards, a steel washer and instaledl disc assembly with the spare tyre. I put a piece of scrap 50mm channel accross the centre to stiffen it up a bit. Spun on another nut and steel washer and adjusted the inner nut to get the right tension on the tyre. Gave the outer nut a belt with the hammer and away you go.
    Note. The ply centres the disc on the outer tyre but the tyre's held to the original spare by the inward pressure of the tyres pressing against each other. All up there's 4 nuts on the threaded bar, pulled against each other with a goodly ammount of ft.lbs. It's a good feeling doing nuts up with a hammer.
    I copied this setup from a mate who used the same set up on his high roofed troopy a couple of years ago. He circumnavigated the country with this setup with no problems.
    The end result looks like this
    I cut the triangular shaped hole so that I could a\. get access to pump up the spare and b\. have somewhere to store rubbish when travelling.
    Will it do the job ? I'll let you know.
    Deano
    Adelaide SA
    Looks good.
    Just don't forget the tyre pliers...
    been there, done that... I used 2 lengths of threaded rod and mounted through the unused stud holes.
    a couple of suggestions.
    1. put a tube in the tyre and inflate it, preferably with a liner from a split rim setup. (this stops you from bending the tyre beads together making future seating nearly imposable)
    2. turn the opening up to the top and goop some heavy plastic sheet over the top like a pocket this will keep dust and water from getting into the tyre.
    May 2009
    How'd you find the spare wheel carrier ? Carry the additional load OK ? Like both of your suggestions, especially the spare tube and sweat band one. It's a real b.....r when you can't get a seal cos the side walls are squashed in.
    Deano
    DeanoH, Blknight.aus,
    Both excellent info/idea's.
    I just used a roof rack when i went across he Simpson, It also held a couple of 10ltr jerry cans.
    But this is just simple & i like it
    Well done.
    Mar 2007
    South Arm, Tasmania
    Have you tried your tyre pliers and checked that you can actually change a tyre on those rims ??
    Pretty sure that I've seen another thread on here somewhere that mentions some pretty specific requirements for using these on Land Rover alloy rims.
    I know from my own experience that, even using the gear in a professional tyre fitting shop, breaking the bead on these rims can be a mongrel of a job because of the safety lips inside the rims.
    While I like your thinking, and Dave's additional suggestions, I'm not sure that I'd be comfortable with hanging additional weight on the back door (too many bad experiences with Toyota barn doors dropping with just the original spare hanging on them).
    You can buy a couple of cross rails that clamp between your existing Land Rover roof rails (I have these on mine). Not expensive (far cheaper than a full roof rack) and they would carry a spare tyre (without rim) or possibly even two without any problem. I have three cross rails on mine (two between the original rails and the third on "tracks" on the rear section of the roof, and I have had some pretty heavy loads up there without any problems.
    Cheers .........
    BMKAL
