Results 1 to 9 of 9
Thread: Centre console
    May 2008
    Frederickton NSW
    Smile Centre console
    Hey guys. does anyone have any pics on what is under the console of the puma defender.I know im being lazy but its just to see what is under it so i can build and underneath drawer and to raise the console up a fraction.I also wish to relocate the electronics from under the drivers seat to under here as well. Any pics of the space under the console would be appreciated.
    Regards:
    Eck
    Jul 2003
    Basically nothing the seatbox carries through.
    4 screws and the console comes out. then it would be a simple job to raise the box to fit what ever you want to there.
    I took mine out to get the aerial lead and power through to UHF radio which is mounted to the side of the console.
    Mahn England
    Ex 300Tdi Disco:
    dmdigital's Avatar
    The cubby is held down on to 4 rivnuts by 4 torx head bolts. This is all on to a panel which is simply screwed in place - 2 at front 2 on each side. The plate is the same otherwise as under a seat and has a foam seal. Under that is the gearbox, transfer case etc. The gap to this is over 2". The whole lot takes about 5 minutes to remove.
    '51 Series 1 80"
    '12 Defender 90
    May 2008
    Frederickton NSW
    Quote Originally Posted by Larry View Post
    Thanks for that Larry. I was looking at that box and thats what gave me the idea.I am going to set it up a little different so that i can store valuables in it and lock it up.
    Regards:
    Eck
    Jannali - NSW
    Quote Originally Posted by eckwalsh View Post
    Regards:
    Eck
    The Ex-Box is lockable.
    Mulgo Pty Ltd
    Expedition vehicles & equipment
    69 Anderson Road, Mortdale NSW 2223
    p 0438 183 507 / www.mulgo.com.au
    Purchase your 4wd gear online:
    www.expeditioncentre.com.au
    follow us on facebook:
    facebook.com/expeditioncentre
    Karalee Qld
    Hi Daniel,
    I had a look at this and it appears it may not fit the SVX model because of the cup holders hitting the stubby lever when in high range if i lift it up with this underneath. Have you had any SVX owners purchase? Do you know if they have had issues? Because I would love this!
    Nigel
    dmdigital's Avatar
    If it's the same as the Frontrunner box (which it looks very much like in the picture) then the lever is cleared.
    Jannali - NSW
    It is not the same as the Frontrunner box, which is not as high - thus would not fit the electronics and won't lift the cubby box to a comfortable height.
    We currently designing one for the latest Defender model.
    Mulgo Pty Ltd
