Results 1 to 10 of 11
Thread: suspension fault
    Feb 2009
    Chidlow, WA 6556
    suspension fault
    Today I noticed the amber suspension fault light came on " Suspension Fault : normal height only" its an '05 4.0 V6 SE
    I thought this might be because I parked it on my driveway which is not flat for about 1 week. Now when i drive it the light goes off after i park the car on flat ground. This is good however whenever i hit the smallest bump ( such as speed bump or gutter or even road bumps) i get " Bing bong" and then suspension fault again.
    Has anyone has this problem before? I just want some ammo before I go back to Barbagellos and tell them to GGF. Ive only had the car 3 months and not even got to go off road yet. I am aware there are prob hundreds on pages of this stuff on disco3.co.uk however i do not have time to trawl through that much info.
    Nedlands, WA
    Not sure!
    Could be the connector behind the front passenger side wheel arch. It has been known to have corrosion problems on some vehicles. The solution is to hardwire. It's a fiddly job but straight forward.
    May also be the compressor is on it's way out. Mine gave up the ghost at arround the 120k km mark.
    Someone else will probably be along with other ideas.
    Sydney, Australia
    Or damaged wiring to any of the height sensors.
    Feb 2009
    Chidlow, WA 6556
    thanks guys. the warning has gone off for now but i will have it checked out at its next service next month.
    Kenya
    I had this when the car was new - I didn't know you had to wait for all the warning lights on the dash to go off (car performs a systems check) before actually starting it.
    Jan 2008
    Same problem but?
    I just had the compressor replaced because of low discharge flow from the compressor.
    G
    elar Guest
    Had the same prob this week while driving Fraser Island - our 1st offroad trip since buying a 2005 SE V6 petrol recently. Didn't slow us down, found that it reset when ignition turned off and vehicle restarted. Certainly gave us a fright though! Kept happening frequently. Intend to take to a dealer this week and get it checked, as well as serviced.
    Feb 2009
    Chidlow, WA 6556
    problem seems to have dissappeared but i will get it checked at its next service.
    Feb 2009
    Chidlow, WA 6556
    went to landrover as it stuck itself in access height whilst i was in the middle of an off road trip.
    Blew the 60A fuse in the compressor and cooked the compressor itelf. New compressor and $1400 later and its good as new
    Sydney, Australia
    Which came first? Cooking, I assume which caused the compressor to seize which blew the fuse?
    What temps were you off-roading in?
