Hi All,
I have just installed a snorkel on a Series 1 '94 Discovery which has had a gas conversion installed, to keep the air fuel mixture correct I understand I need to install a 'balance tube' from atmospheric side of air filter to the breather on the LPG converter (vaporizer unit).
The problem I have is that I am unable to locate the breather on the LPG converter, it is a model BRC AT90E, was wondering if anyone out there has done this or has possibly has photos/description of where the balance tube gets fitted.
Regards,
Matthias
Hi Matthias,
You have posted this in the series 1 section. Series landrovers are those from the 40s to early 80s with leaf springs. Where you have posted is for series 1 landrovers that cover about 1948 to 1958.
I am sure the moderators will move your post the the Discovery 1 section but if not you might want to copy your post there.
