Results 1 to 10 of 19
Thread: Series 1 Starter Button
    Exclamation Series 1 Starter Button
    G'day,
    When i turn my ignition off and take the key out, i go and press the starter button and the Landy still kicks over? Why is this? kinda strange me thinks
    let me know what you all thinks,
    Cya,
    Chris
    Nov 2008
    Same here - seemed odd first time I did it 'by accident'. I'm no electrician, but think I've worked out that operation of the starter is independent of the ignition. When ignition is on, my engine starts first push of the button. If no ignition, I can turn the starter over til the battery dies but no spark(believe me, I did this for about 2 weeks til I sorted my ignition out).
    Maybe someone can tell us if this is meant to happen or if our two landies are both wired wrong?
    D
    Jan 2008
    Hastings, Victoria
    Quote Originally Posted by dreamin' View Post
    D
    Wat you are experiencing is correct operation of your Landy.
    The wiring from the battery goes direct to the starter motor through the start switch. (so as long as the battery has electricty you will be able to turn the starter motor over) All the ignition switch does is switch the iginition coil into circuit, thereby allowing the creation of spark to the spark plugs.
    Hope this helps
    Wal
    JDNSW's Avatar
    As above - this is the way all cars with electric start were until solenoid starter switches became common about WW2. Landrover were probably the last vehicle to change.
    Thanks fellas!
    that makes sense now!
    I used to play in my uncle's Ford Consul when I was a kid and we couldn't work out why it would start as the motor always turned over on the starter - was the same as a series landies.
    Starter is separate to the ignition.
    It gets better. If you connect a wire from the accessories socket to the terminal on the windscreen wiper, the Land Rover is now switched on. No key necessary.
    Aaron.
    It gets even better still. If your vehicle is a diesel, you don't even need a battery. If you can hand start it (Hercules) or push start it (everybody else), all of the electrics will come on-line once the engine is running.
    Aaron.
    Nov 2008
    So what happens with crank-starting petrol models? Does there still need to be enough battery to deliver a spark even if it can't turn the starter?
    Melb. Vic.
    Still need the power on to deliver the spark - using Aaron's method above - or the more popular "key" method
    And no, I am not telling you where I park my S1
