Results 1 to 4 of 4
Thread: how to lock the center diff on 85 county
    Jas71 Guest
    I have just got a 85 county V8, can you tell me how to lock the center diff as i can't work it out. I have the high/low rang worked out. DA
    4-speed or 5-speed gearbox?
    Sunshine Coast
    Jas71, if it's a 4 speed, just pull out the little black knob on the seatbox directly above the transmission hump, and to the left of the low/high range lever.
    If it doesn't work you may have a vacum leak or the diaphram may be had it.
    Evelyn
    Jas71 Guest
    Thanks yer i had a look and found it
